Use the following procedure to configure the minimum version of the TLS protocol.
Disable the web server before changing the TLS version. By disabling the web server, other existing users with a connection to the web server are not affected by changing to a different version.
The switch, by default, supports version TLS 1.2 and later. You can explicitly configure TLS 1.0 and TLS 1.1 version support.
- Select General.
- Select the Web tab.
- In TlsMinimumVersion, select the TLS version you want to configure as the minimum on the system.
- Select Apply.
Web Field Descriptions
Use the data in the following table to use the Web tab.
Name |
Description |
WebRWAUserName |
Specifies the RWA user name. The default is admin. |
WebRWAUserPassword |
Specifies the password for the RWA user account. The default is password. |
WebROEnable |
Enables the web server read-only (RO) user, which is disabled by default. |
WebEncryptionType |
Specifies the ciphers for preset version of TLS for the web server. |
WebCertSubjectName |
Specifies the digital certificate subject Name used as identity certificate in the web server. |
WebCertCAName |
Specifies the digital certificate CA trustpoint name used for the certificate in the web server. |
WebROUserName |
Specifies the RO user name. The default is user. |
WebROUserPassword |
Specifies the password for the RO user account. The default is 12345678. |
MinimumPasswordLength |
Configures the minimum password length. By default, the minimum password length is 8 characters. |
HttpPort |
Specifies the HTTP port for web access. The default value is 80. |
HttpsPort |
Specifies the HTTPS port for web access. The default value is 443. |
SecureOnly |
Controls whether the secure-only option is enabled. The default is enabled. |
InactivityTimeout |
Specifies the idle time (in seconds) to wait before the EDM login session expires. The default value is 900 seconds (15 minutes). |
TlsMinimumVersion |
Configures the minimum version of the TLS protocol supported by the web-server. You can select from the following options:
The default is tlsv12. |
SSLRenegotiation |
Specifies whether SSL renegotiation is enabled or disabled. The default is enabled. |
HelpTftp/Ftp_SourceDir |
Configures the TFTP or FTP directory for Help files, in one of the following formats: a.b.c.d:/| peer:/ [<dir>]. The path can use 0–256 characters. The following example paths illustrate the correct format:
DefaultDisplayRows |
Configures the number of rows each page displays. The default is 30. |
LastChange |
Shows the last web-browser initiated configuration change. |
NumHits |
Shows the number of hits to the web server. |
NumAccessChecks |
Shows the number of access checks performed by the web server. |
NumAccessBlocks |
Shows the number of access attempts blocked by the web server. |
LastHostAccessBlockedAddressType |
Shows the address type, either IPv4 or IPv6, of the last host access blocked by the web server. |
LastHostAccessBlockedAddress |
Shows the IP address of the last host access blocked by the web server. |
NumRxErrors |
Shows the number of receive errors the web server encounters. |
NumTxErrors |
Shows the number of transmit errors the web server encounters. |
NumSetRequest |
Shows the number of set-requests sent to the web server. |
